Frequency for Focal ES165 KX2
  • 4
Those your only speakers? Do you have dedicated midbass speakers too? What sub and where is it set?
General rule, if that was your only speakers and a sub. I would set the tweets at 3.5 to 3.8k. The high end on the woofers to about 2.8 to 3.2 depending on your slope and the low end around 100 with a 12db slope (assuming you have a sub set around 80 also with a 12db slope)
Stick with -24db slopes and cross them closer. That will let you bring the tweeter down to 3.5k and still keep the mid in phase.
Be careful with the tweeter. They are not the best down low.
Focal tweeters are crap in a 2 way. I guess it's to late for you to know that now.
As for the mid. Try 80 at -12 and 3.5k at -24. The low end will depend on how high the sub can play. Don't be scared to bring the sub if it can do it.
How are Focal tweets crap? The ones with the power ES series are great. You just don't aim them on axis.
For a 2 way you ideally want a tweeter to cover down low enough to keep the mid range from beaming. They can't do it. A lot of that Focal brightness isn't so much the tweeter. It's the big spike in the mid from playing higher then it should. A 6.5 should be cut off under 2000hz if all possible.
This is one of the best sounding mids ever made. It's a bit oversized so the Focal would spike a bit higher. But you can see the response head upwards past 2k. That's also one of our most sensitive ranges.
https://www.madisoundspeakerstore.com/scanspeak-woofers-6-7/scanspeak-revelator-18w/8531g-00-7-mid-woofer-8-ohm/?gclid=EAIaIQobChMInv6cncmt1QIVQx1pCh0RyApMEAQYAiABEgJNPfD_BwE
No mid bass. I have one 12" Hertz sub. I have no knowledge on frequency at all. So on Helix DSP I have to put Highpass and lowpass on tweeter, mid, and sub.
From your suggestion I should put 3.5k on tweeter highpass and 3.8k for lowpass. 2.8k for highpass and 3.2k for lowpass on Mid. How about the sub?
Thank you,
Stick with -24db slopes and cross them closer. That will let you bring the tweeter down to 3.5k and still keep the mid in phase. Be careful with the tweeter. They are not the best down low.
I have no knowledge about frequency at all. What is your suggestion numbers for this Focal mid and tweeter also one 12" Hertz sub.
I have to input frequency on Helix DSP as first number for tweeter highpass and second number is tweeter lowpass. Same as mid and sub. Please advise what are the best numbers for me at the moment, also don't want to damage my tweeter.
Thank you,
Thank you,
Do what I said. You will have to use your ears to dial it in. There isn't a magic number. Don't lowpass the tweeters. They play all the way up.
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
477
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
980
Trust your ears. If your soundsystem rolls off early without a sub, then cutting high Can be beneficial. Most cut around 80hz, but I have had good...
Tony1234
Tony1234
rancho cucamonga, ca
Papermaker85
    May 12, 2024
Brendon Jenness
    May 11, 2024
