So I am currently using factory bose in my 07 Tahoe, I added an AudioControl LC2i with a Crescendo BC2k on a Sundown Xv2 12 (2.75cu ported @32hz), big three (KnuKonceptz 1/0 ofc) and group 31 battery. My plan for the sub stage is 2 upgraded SA-15's in a ported enclosure and then a bigger amp once I've added an upgraded alternator. The factory bose already has a hard time keeping up and will no doubt be completely lost when I go louder...not to mention is sounds mediocre all by itself. I have a Pioneer AVIC-8100nex and a Sundown sax100.4 ready to go in. I'm not committed to going active yet but I would like to pick up a set of components that sound good with a budget of around $500 at the top end (I still want those **** H.A.T. Clarus 6.5's though) and using factory mounting locations. I would also like to take advantage of the output at 2ohm's if possible but I'm not married to it.
Goals for the fronts would be SQL I suppose. I don't always want to cave my brain in so I would like for my setup to have a solid amount of SQ. I know that a lot of the output quality/quantity is all in the install. I plan on fully dampening my doors (unsure which material to go with yet) and using FAST rings as well as adapter rings. I am just lost as to where to go from here. I've had my eye on the following components:
Sundown SA-6.5cs
H.A.T. Imagine 6.5
B2 HNC6.1
CDT HD-61 (2ohm)
and some others I can't remember
My music genres include: Rap, Rock, Classic Rock, Various Electronic, Ambient, Re-bassed (Decaf etc.), Reggae, and more.
I guess I use the knob (PAC L1 I believe) to adjust the subs, I just want something that has the capability to hang when I try and break the knob off as well as when I am in the mood for semi-critical listening. I know that the ultimate goal is active but I'm just not ready yet - I feel like I've got much more to learn before I take that step as well as the need for more time to play with tuning etc.
Am I asking too much from one set of components (probably) or is there something that will be able to meet those needs or at least come close. In an ideal world, I'd do custom door panels or add another set in some kick panels, but I just don't have the funds for that just yet.
Thanks in advance for the input, glad to finally be a registered member of the forum and I look forward to hearing input from people who have much more knowledge than I do!
Sundown SA-6.5cs
H.A.T. Imagine 6.5
B2 HNC6.1
CDT HD-61 (2ohm)
