fourth order for apxx18?
RangerDangerV2
st cloud MN
so I will def be doing a new enclosure for my 18... and a fourth order came to mind..
heres what I was thinking.
3 cubes sealed ( sub inverted)
7 cubes ported
tuned to 45
Idk much about these so any help is appreciated... and what should I go with for port area??
[quote name='falcons03079313']make up your mind jakeapotamus[/QUOTE]
im very indescisive but Im going with a fourth order for sure this time.
---------- Post added at 10:25 PM ---------- Previous post was at 10:25 PM ----------
and does 6 cu ft ported sound good instead of 7?? @Moble Enclosurs @Buck @pro rabbitt
UNITS APXX10D2 APXX12D2 APXX15D1 APXX18D1
Revc (ohms ) 1.00 3.60 1.80 2.00
Fo (Hz) 45.06 42.20 39.80 38.34
Sd (sqM) .0330 .0550 0.089 .1195
Bl ™ 17.94 37.66 27.11 26.88
SPLo (dB) 91.92 94.34 95.46 97.10
Xmax (mm) 10 10 10 10
Dvc (mm) 75.00 75.00 75.00 75.00
Qms (m.q.) 6.31 2.83 3.12 5.81
Qes (e.q.) 0.106 .133 .175 .187
Qts (totQ) 0.105 .127 .165 .181
Vas (liter) 18.57 31 63 112
Cms (uM-N) 120 72. 56 55.2
Mms (gram) 141 197 285 312
Low xmax, really high EBP (depending on accuracy of t/s parameters), I still think a different enclosure would work better.
Doing a 148 out of a trunk is just that, we don't know what your goals are.
he knows im a meter chaser sooo.... lol
xmax is actually 20 peak to peak sooooo....
---------- Post added at 11:28 PM ---------- Previous post was at 11:27 PM ----------
and I would like to meter high but I am leaning more towards groundpounding...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
369
There its designprogram to use fore bass boxses , if you now all parametre of the subwoofer , the made the best solutuon fore you
49
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
798
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
936
RangerDangerV2
RangerDangerV2
st cloud MN
Moble Enclosurs
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
