fourth order for apxx18?
[quote name='falcons03079313']make up your mind jakeapotamus[/QUOTE]
im very indescisive but Im going with a fourth order for sure this time.
---------- Post added at 10:25 PM ---------- Previous post was at 10:25 PM ----------
and does 6 cu ft ported sound good instead of 7?? @Moble Enclosurs @Buck @pro rabbitt
UNITS APXX10D2 APXX12D2 APXX15D1 APXX18D1
Revc (ohms ) 1.00 3.60 1.80 2.00
Fo (Hz) 45.06 42.20 39.80 38.34
Sd (sqM) .0330 .0550 0.089 .1195
Bl ™ 17.94 37.66 27.11 26.88
SPLo (dB) 91.92 94.34 95.46 97.10
Xmax (mm) 10 10 10 10
Dvc (mm) 75.00 75.00 75.00 75.00
Qms (m.q.) 6.31 2.83 3.12 5.81
Qes (e.q.) 0.106 .133 .175 .187
Qts (totQ) 0.105 .127 .165 .181
Vas (liter) 18.57 31 63 112
Cms (uM-N) 120 72. 56 55.2
Mms (gram) 141 197 285 312
Low xmax, really high EBP (depending on accuracy of t/s parameters), I still think a different enclosure would work better.
Doing a 148 out of a trunk is just that, we don't know what your goals are.
xmax is actually 20 peak to peak sooooo....
---------- Post added at 11:28 PM ---------- Previous post was at 11:27 PM ----------
and I would like to meter high but I am leaning more towards groundpounding...
RangerDangerV2
RangerDangerV2
st cloud MN
Moble Enclosurs
