Ford Mustang Coupe 1994 - 2004 Dual 12" Custom Sub Box Sealed Enclosure (Black)
  • 2
Athletestar123
Features:
Ford Mustang Coupe 94-04 Dual 12" Subwoofer Box Enclosure
Air Space: 0.80 Cubic Feet Per Sub
Mounting Depth: 8"
Sealed Enclosure
Dimensions: Width 48-3/4" x Height 9-3/4" x Top Depth 13-3/8" x Bottom Depth 11"
Constructed with High Quality MDF
High Quality Binding Terminal Cups (Accepts Banana Terminal Plugs OR Bare Wire 'up to 10GA')
High Quality Black Carpet
Enclosure installs in the trunk and the subwoofers fire towards the rear
Mustangs equipped with the Mach system - you need to remove the amp rack under the rear dash for box to fit.
This box fits:
1994 - 2004 Ford Mustang Coupe
Width: 48-3/4"
Height: 9-3/4"
Depth One: 13-3/8"
Depth Two: 11"
Cutout Diameter: 11"
Box Volume (Cubic Feet Per Chamber): 0.8
Mounting Depth: 8"
Box Type: Custom
Box Color: Black
Fit Location: Trunk
Box Finish: Carpet
Material: MDF
MDF Thickness: 5/8"
$65 SHIPPEDDDDDDDDDDDD !
I ordered the car with the upgraded B&O audio system....turn's out Ford bought the name but they didn't buy the quality. The system ****** to me...
763
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Athletestar123
Athletestar123
South Carolina
Athletestar123
    May 24, 2024
    May 23, 2024
