ford fiesta mk 5 set up
  • 2
it honestly doesn't matter that much if the budget is limited and the HU is the source. spend as much as you can, install them with weatherstripping foam seals front and rear.
being in the UK, your access is different than ours. We don't know what your local shops carry.
609
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
fordfiesta
fordfiesta
london
keep_hope_alive
    May 18, 2024
    May 16, 2024
