few questions
Bobby322
TX
Just wired to my single d2 sub to 2 ohm to each channel on each vc. the amp is an ap30001d and it says 1500w @ 1 ohm per channel, so any idea on what power i am seeing? Just got a volt meter and I stay in high 13s and low 14s. Also I think my settings might be off on the amp, this is what I have:
Gain - half
LPF - ~145
subsonic - off
Bass Boost Freq. - ~60Hz
Bass Boost - off
I have my bass on my HU to 0, and HPF is off and my box is 32Hz. So any idea on what my settings should be at? I tried setting them to my ear but im not sure what I should be looking for.
thats 3000w total at 1ohm....just found the specs....does 950x2 @ 2ohms...so you are pushin about 1800w...give or take
Where did you find that it does 950 @ 2?
Lmfao.... You wanna go check it out and say that?
Could an inactive site afford to giveaway a RD Audio D9
And look at you? i at least try to help the guy by giving him a place to actually GET an answer while you just come here to diss on ME not even answer the guys thread...
Loser...
bobby i dont think u wired ur subs to 2 ohm each channel. dual 2 ohm subs can wire to 1 or 4 ohm. u cant wire one dual 2 to 2 ohms. so each channel is seeing 1 or 4 ohms. did u wire them in series or parrallel
Lmfao.... You wanna go check it out and say that?Could an inactive site afford to giveaway a RD Audio D9
Loser...
Thats funny looked like he gave advice not once but twice. Even found the specs on the amp as well. What the OP was looking for. SOOO goodluck with your up and coming website
There you go boddy 1800 rms too. So if that amp is anything what ppl have been raving about. It should do your 15 quite nicely. Id keep. Work on your box and set your gains with your DMM.
Well 1800w is only a little over half of what the amp can do. But im impressed with only ~1800
yeah but you got to think as well. Thats RMS. Each channel is 950 RMS. Not max so on peak notes you should see more. Even with your eletrical you have. Nothin below 12 volts. Id say you should see that and some.
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
987
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
I found this, can it be done with snapon modis ultra scanner which i have...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
322
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Bobby322
Bobby322
TX
dafobbishon3
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
