F/S Pair of Alphasonik 12" 400watts rms dual 4ohm subs. Cheap.
ampjunkielikeme
nash, tn
Item(s) for Sale: SOLD SOLD
a pair of lightly used alphasonik PSW212 , 12 inch subs. series 200
(if you want to see some pics with user name. let me know...) i have tons of refs on here...
I got these subs in a trade and have no use for them... maybe they could be used as a budget build. or for your g-friend. or just something to have some bass to listen to... i need them gone!
the subs are in very good condition. they do have some light scuffs on the rubber surrounds. (more like a discoloration. nothing is worn)... it has a aluminum heatsink covering the motor to keep it cool.. allen head bolts for the speaker wire connections..
with all the voice coils wired up together. you can get a 1 ohm load , or a 4 ohm load .
specs: (for each sub)
Sensitivity: 90 dB
RMS Power Range : 400 Watts
Impedance: 4 Ohm
Low Frequency response: 25 Hz
High Frequency Response: 500 Hz
Diameter: 12 Inch
Number of Voice Coils: Dual
Proprietary Heavy Gauge Stamped Steel "Alpha" Basket
Proprietary Cooling Rings for Motor Assembly
High Rigidity Inverted Dome Mineral-Filled Composite Cone
EPDM Surround for Enhanced Control at Extreme Temperatures
Flat Progressive Rate Nomex® Damper w/ Spiral-Woven Leads
30 oz. Double Stack Magnet
Dual 4 ohm 2" Voice Coils
8-Gauge Lug-Lock Input Terminals
Mounting Dimensions Depth: 5 1/4"
Through Hole: 11 1/8"
Diameter: 12 7/8"
50.00 shipped for 2 subs shipped to your door..(in the cont usa).. no trades...
subs will be packed up nice and will have insurance...
these are pics of both subs with the 4ohm coils wired up for 2ohm
here is the other one reading 1.9
how did these sound? will they work alright in a sealed enclosure?
they sound very nice sealed up. the subs were originally in a sealed pre-fab s-10 extended cab box. you can have the box if you pay the shipping...lol
these subs are still for sale........ and i dropped the price again...... somebody buy these..
it will probably cost me 20+ dollars to ship them.
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
10K
I still have some Old school stuff that I really enjoy to this day. I still swapp amps and other gear I have from time to time and run for a...
17
ampjunkielikeme
ampjunkielikeme
nash, tn
ampjunkielikeme
    Jun 1, 2024
    May 31, 2024
