EQ options >$150??
only problem is a unit with both in one is going to get expensive and there are not many around.
The easiest solution for you would be to upgrade the HU and get one like the 800prs or 9887 9886 that can do both
doesn't have to be a single unit. i can swing a 3 way x-over and a separate eq. best cheapest way is the goal.
i also need some mids/tweets. see my wtb thread
i have no idea what features to look for, other than the most basic. as far as slopes, octaves and all that jazz............no fcking clue
the steeper(higher number) the slope/octave, the quicker frequencies will be cut above/below set frequency.
so if you have a steeper slope per octave, then you can tune the frequency closer to the speaker's limit....
say you set a hpf to 100hz: a steeper slope (assume 30db/octave)means that 50 hz(one octave below 100hz) will be decreased in output by an equivalent of 30db.
once again hpf @ 100hz: this time a shallow slope (assume 15db/octave) means that 50hz will be decreased in output by an equivalent of 15db.
output wise, the steeper slope(30db/octave) will create less sound @ 50hz than the 15db/octave slope
this can be said continuously down the frequency range by octaves
A while back Louisiana CRX said he had bought one of these off ebay-
MA Audio MA30EQX
30-Band Parametric Equalizer w/ 3-Way Crossover
Buy It Now price: US $135.00
http://cgi.ebay.com/MA-AUDIO-MA30EQX-30-BAND-PARAMETRIC-EQUALIZER-CROSSOVER_W0QQitemZ360063031554QQihZ023QQcategoryZ14931QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I dont know anything about it, but it seems to have everything except time alignment.
Oh, and that same seller also has it in a 15 band version if 30 is too much.
jco1385
expert jcologist
jco1385
Mobile, AL
Etac
