Dvc question
Yes, if you run your Audiobahn with only one coil it could end up blowing the other. Anyway each coil can only handle half the power so running it with just one is just a stupid idea. And I KNOW you wouldn't be that dumb.
On the contrary I say no you won't hurt the sub. You loose power handling and the electrical q changes. But it won't hurt the sub. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That's the whole point of DVC speakers. If you can't use only one coil, then you might as well buy a SVC at whatever impedance you need. A D4 sub could never be 4 ohms, a D2 could never be 2 ohms.
I know JL says never use only one coil on their subs, but they're the only ones. Kicker has instructions for it in their literature... just cut the power handling capacity in half.
the point of a DVC is wiring options. You can run 1 coil. just reduce the power handling by half and short the other coil with a wire. This will keep all thiele - small parameters the same
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
362
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
4
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
XtremeBass
XtremeBass
Lehighton Pa
chris229
winkychevelle
    May 24, 2024
