Well moron if the op didn't have the funds to get a recone, then he would have no choice, I have been in that situation. Had a dd 9515 blew out a vc and just used one still worked fine. You just proved yourself to be ignorant. Would you like to try again?
Just because it works doesn't mean its right.
Would 12 gauge power and ground wire on a SAZ3000d work?
Yes it would turn on and operate.
Is it the right way?
No, you'll probably melt the wire and damage the amp due to voltage drop issues.
Using 1 coil of a dvc sub will change motor strength, efficiency, frequency response, and power handling,
SURE IT WILL WORK, but who wants muddy, low volume non-linear response?
Oh I forgot. It worked for you so continue giving bad advice to others.
Say what you want but that is a half-assed install method and only acceptable for very short term.
I did it once and it was a waste of time, the other coil blew in less than 20 minutes.
So my point is I gave someone my honest, helpful opinion, you come in and say NEWBS! HURRR!
While being disrespectful and offering no helpful advice.
