Dls Mw12d Sub??
daniel999hm
4
tg
Hi, did anybody experienced or owned DLS 12MW subwoofer?? I'll be thankfull for any impressions or reviews.
It will be connected to Focal Solid 1 amp! So, how big enclosure must be to get out the full range of this sub, any idea and advises will be usefull?? Also i wants to go with this sub very low in frequencies. DLS recommended enclosure of volume 35 litres,port 4" x 20 cm(http://www.dls.se/files/482/2/Man_MW10D_12D_eng.pdf), but is it the best enclosure for this great SQ subwoofer, that is the question??
ps:i'm listening reggae,dub and hip-hop
Specifications(DLS 12MWD):
Impedance 4 ohm
Woofer size 12" (30 cm)
Power handling capacity 400 W RMS
Max power handling capacity 600 W
Peak power 800 W
Frequency range 20 - 2000 Hz
Sensitivity 93,5 dB (1W/1m)
Magnet size 180 mm (7,09") 140 oz
Outer diameter of woofer 313 mm (12,32")
Mounting depth 153 mm ( 6")
Mounting hole 282 mm ( 11,1")
Weight 9,7 kg (2,13 lbs)
X-max +- 9 mm (0,35")
T/S parameters
single V/C Fs 39,8 Hz Re 3,5 Ohm Qms 3,16
Vas 64,9 liter Vas 2,29 Cuft Qes 0,28
Qts 0,26 Sd 531 cm² BL 17,5
daniel999hm
daniel999hm
tg
daniel999hm
michigan born
    May 14, 2026
michigan born
    May 14, 2026
