Different Style Setup
Holy rattle... Sounds horrible...
Yea i need to deaden alot more that was enough for my hds312 but the tantric meeds more. I also have thi stupid noise under my bumper and i have no idea what it is... But the tantric slams
I am willing to sell the shark if the right offer is there. But I am contemplating a sealed 15 or something or 2 12's sealed. not entirely sure.
For 10s, I have a pair of Dayton DVC4 ohm HOs also if any interest
^^^ this would be a great way to save space and have nice bump.
@zcarlson1; honestly, I wouldn't go sealed especially for the type of music you listen to. The only way MD's sealed would be worth it is if you had a lot of power to back it up with and that's more expensive than going with a small ported box. Dayton HO's would be a great solution to your space problem. How do you think I was able to fit 4 10's in a 3.2 cu ported box?
What are the dimensions on your box?
The outside dimensions are 28L x 13.75H x 22W. It's actually kinda big because of many reasons. Double baffled the top, the subs needed spacing between so they don't touch anything, and I needed the port to fit inside. 2 15's might be more practical for you since you have more height to work with. What are the dimensions of your current box right now?
I can't go above 16 inches in height because of the trunk cover so I make sure nothing gets stolen. Max dimensions on box are my max period - 37 long, 24 deep, 16 high - sub up port back
So how much smaller are you trying to go? or is what you listed the max you willing to go? The 2 15's facing up and port back would work in that space. Or if you're really trying to downsize, then 2 12's.
Dayton Audio RSS390HO-4 15" Reference HO Subwoofer 4 Ohm
sold out right now but will be restocked by next week
As long as you don't overpower them, there is no danger of harming your gear, once you get a new sub so they are both the same, you will likely...
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
Savackz
Savackz
GA
Savackz
Decebal
    Jun 10, 2024
