DD9512g - Ford Taurus 99 - ED nINE.1 - eDead
Yeah, but i'll have to do it later. Studying for tomorrow mornings mid terms at the moment.
Thats fine...GL with that //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif yea just toss me a PM //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
PICSSSSSSSSSSSSSSSSSSSS.....
Kenwood HU
40' of eDead 120
Amp Settings
New Box - 2.5 Cubes - 35ish tuning?
36 models up much more peaky than 32hz does. 36 will be quite loud around 35-42hz, but has a horrible rolloff for the low lows and lacks output from 50-80hz as well. 32hz would make it a much better daily box in terms of playing the full range of 80hz and down. 36 would definitely increase the output at mid to upper 30's and low 40's, but the rolloffs ****
are you basing all this off winisd or have you actually played around with DD subs? I've heard over and over that they don't model well or correctly and your results seem to support that.
I've gone as low as 35Hz and as high at 42Hz and have never had a problem playing any freqs in the music I listen to. I'm not saying these are comp SQ builds, but they can sound very good and blend quite will with a solid front stage.
I do have experience with DD (not 30+ builds if you arent lying though). And i didnt say tuning to 35hz-42hz was "bad".
Wasn't trying to bash, sorry if it sounded that way.
I've never had a problem playing well below tuning with the boxes I've done. My current set up is tuned to 36Hz for daily and I play 31Hz with no issues. I do all the builds for Team DOA, so that's why so many enclosures. Also when I still had a trunk set up I'd built various boxes tuned high and low, lots of port area, etc... just to see how they actually sounded.
I might have missed it, but what is the music of choice for the OP? Assuming it's mostly rap then "SQ" really isn't an concern. Otherwise I personally like 38-40Hz for rock, jazz, blues, etc... and having a decent EQ available can help a lot to get a flatter response.
Got the trunk lid covered in eDead. First time messing with this **** so it looks REALLY bad, does the trick though //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. Rest of the trunk should be getting finished later on this week/weekend. I got a vid uploading to youtube right now with some flexing going on. I still have about ~37ish sq feet of eDead left so I am hoping that should be enough to finish the trunk. Seems to be the main issue right now is with the two air vents on the right and left sides of the trunk letting air out when the lower freq hit (they make a very loud flapping noise, hoping the eDead will fit it or I will just take them out.
God awful I know.....LOL
Next post will be the vid //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
918
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
raz0rxx
raz0rxx
Mount Pleasant, MI
raz0rxx
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
