LosIsATool
I don't need to. I was told Buy builders I trust.look up on NEC code under shield signal cables.
Just like the Knu cables. Shield isn't grounded.
learn the difference between SHIELD AND A DRAIN..I don't need to. I was told Buy builders I trust. Just like the Knu cables. Shield isn't grounded.
I know the difference. I'm waiting to give you the answer. If I'm wrong I'm wrong.learn the difference between SHIELD AND A DRAIN..
want to know if it works? Take a aluminum pot get a magnet. The get a peace of steel see if the aluminum has lowered the field strength without the aluminum being grounded. If it is weaker then you have your answer.Sheilds block magnetic induction they don't need a drainDamien said he will get on here later and help you out.
Why don't you just wait a bit and get it straight from the source?want to know if it works? Take a aluminum pot get a magnet. The get a peace of steel see if the aluminum has lowered the field strength without the aluminum being grounded. If it is weaker then you have your answer.Sheilds block magnetic induction they don't need a drain
A drain is a good idea incase you get noise you can rid that noise to ground but since your cars body is isolated from a true earth ground you are putting noise back into the ground hoping it dissipates or goes elsewhere and is filtered or isolate the ground from the cars grounding system.
Why don't you stop trying to google everything and have a conversation with people that do it for a living?http://www.mouser.com/pdfdocs/alphawire-Understanding-Shielded-Cable.pdfhave a read. this is about as deep as it gets. lol
i have been an electrician for 14 years. not all cabling requires a shield or darins and some cable has both. I provided the actual facts from a cabling manufacture. i don't what else to tell you honestly. .Why don't you stop trying to google everything and have a conversation with people that do it for a living?
I don't want you to tell me anything. I want you to shut up and listen for a change.i have been an electrician for 14 years. not all cabling requires a shield or darins and some cable has both. I provided the actual facts from a cabling manufacture. i don't what else to tell you honestly. .
if you worked for me I'd Donald trump you.I don't want you to tell me anything. I want you to shut up and listen for a change. I don't even think it's possible with you. If worked for me I'd choke the **** out of you.
