Car stereo with simultaneous AUX and USB audio playback?
  • 1
SuddenlyBass
So, here's the deal... my gps unit has a 3.5mm audio output, so I figured why not connect it to my stereo... but the thing is, I still want to listen to music in the car... while at the same time receiving voice commands from the GPS unit.
Playing the audio from the GPS itself is not an option unfortunately...
A perfect solution would be a stereo that would switch to the AUX input whenever there was sound coming from it and then return to the USB audio playback / CD / Whatever it was playing when there's nothing coming from it.
How can I accomplish this? Even if you don't have a concrete answer, any help/opinion would be appreciated! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks in advance!
You can go to theyre Website and check it out/do some research on your own, or even give them a call
33
7K
It should be called the accessory wire...it should be connected so that it only see power when the car is on...if its connected to constant power...
860
Unless Android made some big changes to their core program, it should work just fine. Just like using a 4g phone on 5g sevice.
If the original plugs have been cut off, you may want to get some from a wrecked car. You could also search online for a radio pin-out for said model.
SuddenlyBass
SuddenlyBass
Portugal
SuddenlyBass
    May 16, 2024
    May 16, 2024
