Capacitors or batteries?
thats not what AS&S's july 2002 issue said...."Alternators are the fastest power source meaning they can respond to power needs more quickly than the battery or even a capacitor"
I've replaced my alternator from a 85 amp to 105 amp which isn't all that much but my headlights dim still. Is it fair to asume 1 farad cap for every 1000 watts?
Originally posted by taylor thats not what AS&S's july 2002 issue said...."Alternators are the fastest power source meaning they can respond to power needs more quickly than the battery or even a capacitor"
Alternator doesn't have the ability to "react" the way a battery or capacitor does, they just supply, batteries and capacitors are storage units. Alternator is constantly on while the vehicle is running, whereas a cap or battery is only as good as its source. While their idea is cute, one has to take into effect the alternator has to react through a supply line of 20 feet, wheras a capacitor is directly at the amp in the shortest lead possible.
I find capacitors useless when you beef up an alternator. Tried them found them pointless. Kept them in because I didn't want to rewire everything under the sun after I wasted my time getting them in there in the first place... Power dispersion rates compared to an alternator, a capacitor will kill it in a heartbeat. Only problem is a capacitor can't supply a charge at a constant voltage, just store one and dissipate what it has stored. All falls back on the alternator.
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
Just the amplifiers use batteries to power it up. The HU are powered up by the car battery supplying 12 volts. The wiring harness...
caraudiogod
caraudiogod
Kansas
bass_mekanik
    May 12, 2024
Brendon Jenness
    May 11, 2024
