Cant fit my **** wire ring on my 4 gauge wire
I doubt you're still having a problem.. but if you are, you should just push the two together while spinning the piece you're trying to get it to go into. Push hard and keep spinning.
The two what?
I have not really messed with it yet. Was about to try now
Also, be careful when u strip the wire and keep squeezing real tight, I had som problems at first with some of the same wire, but if you're really careful you can get it in to the ring terminal first try. Just make sure you hold it all together right after you strip it. Then as every1 else said, it's okay to trim off the couple strands that don't get into the terminal...
darkhunter139
darkhunter139
PA
Alpineforever
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
