Camry alarm question
  • 4
cwehrer707
I've got a question about the stock alarm on my 98 Camry LE. I've searched for answers but couldn't find anything. My question is does the stock alarm (Karr) go off when the windows get smashed? I don't know if it does or not. I'm asking because I want to get a double din dvd hu.
If your bypassing the infotainment stuff in the original HU setup, then the LCi7PRO should handle the rest. If you want to retain the handsfree...
I am going to have to pull it out of the dash and have a look again to see if the wires are correct. I sent over this with a pro shop many times...
cwehrer707
cwehrer707
Petaluma, CA
cwehrer707
