big 3 help
  • 5
Proceed as planed to the best of your ability up grade from alternator to battery with whatever it takes to get that wire upgraded. Do the same with engine and frame ground body to battery.
Have fun and enjoy doing the best you can with it.
There are many different kinds of side post adapters at the auto parts stores and car audio shops.
Side post adapter. Just like the previous poster mentioned. Any auto parts store should carry them. It replaces your stock battery bolt that screws into the side of the battery.
Yep any auto parts store will have one adapter or sorts that gives you alot more options with your terminal. I used a big silver one and was able to fit 1/0 in all the spots and still have it all cranked down nice and tight. I admit, i bought some pre-terminaled and color coded wire from a fellow forum member in here with all 1/0, and just added a 200A fuse for the alternator to battery positive.
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
southpoleman69
southpoleman69
lancaster,pa
southpoleman69
