You know if you could find a good 2 channel that would work well. Larger 2 channels can be bridged and ran at 4 ohm. That one that Audiobaun had mentioned would be excellent. Do you know anything about impedance? I mean could you handle rewiring the speakers down? That would be another option. 600 @ 1 ohm is a little easier to find and cheaper than 600 @ 4 ohm. If you want to stick with Sony (I wouldn't as far as amplifiers but...) here's a 2 channel that does 540 @ 4 ohm bridged which is pretty close. http://www.onlinecarstereo.com/CarAudio/p_25439_Sony_XM-GTR2202.aspx?utm_source=pricegrabber_shopping&utm_medium=Product_Feed&utm_campaign=pricegrabber_shopping_Price_ComparisonThey wanted $100. They said it already sold. I thought it put out more than that... Thanks for the update.
it will get loud to the point to where you can put the subs into distortion and burn them up if you consistantly do it.P.S. Dumb question, will hooking up to a more powerful amp allow me to SIMPLY listen to it louder? Or will the sound quality improve at any volume level?
Ok... Hhmmm. Maybe I'm barking up the wrong tree, and may not even need a better amp. I just figured that the ratings for the subs were so much higher than the specs of the amp that I figured I was doing an injustice to my ears.... I'm not looking to compete - just want nice sound.it will get loud to the point to where you can put the subs into distortion and burn them up if you consistantly do it.
I would never pay $100 for that.Would this amp be TOO powerful? I found it locally for $100
Lanzar - HTG157 - 3000 Watt 2 Ohm Mono Block Mosfet Amplifier
If you want cheap and good, hit the classifieds here. you'll do better than cheap new garbage like ^^^ that...Would this amp be TOO powerful? I found it locally for $100
Nobody has mentioned this yet, and don't take this as an insult, but those woofers are at the bottom of the spectrum of what we usually utilize around here. I think everybody has been friendly about it because you are asking legitimate questions without sounding/acting retarded. I applaud you for this. Keep coming back with questions before you make any big decisions and we will readily help you along the way!
that is a good deal!
