Audiobahn sub
but the 4 12's would give the best because there cone is not as big and it could move fast than a 15.
Sorry, try again...transient response doesn't have much to do with cone diameter alone //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif More factors are in play, like the BL curve/motor strength.
motor strength is a important part but a 15 will give off deeper bass because of its cone size, and it can take in lower frequency response better than a 15. The 12 will give off a more clear and boomer bass sound but the 15 will out beat it on the deep bass part.
No it won't! The 15 will just play deeper and take up more space, that's it.
That big woofer being slow shit is a myth!
4 15's in a wall would give you that deep bass but the 4 12's would give the best because there cone is not as big and it could move fast than a 15. And it depends on the set up your going for. Are you going for Sq or SPL set up?? and are you going to do a ported or sealed box?
it's going to be more of a spl setup and it's going to be ported
Like i said before i would go with the 4 12's . Put two 12's in one box and build it like Re wants you to and just build another box for two more the same way, and then put them on top of each other. Have you be to the RE web site??????
yes i have
ok this is what i would do, i would get the 4 12's in a ported set up and wire two 12s to each amp and get upgrate to 2 alternators, and get one two opitum batterys and use 4ga for speaker or lower so the electric current flow throw faster. and after that your ready to go shake and break some things
ok this is what i would do, i would get the 4 12's in a ported set up and wire two 12s to each amp and get upgrate to 2 alternators, 2 capasitors ( one ffor 2 amps)that are 24volt and get one two opitum batterys and use 4ga for speaker or lower so the electric current flow throw faster. and after that your ready to go shake and break some things
i'm going to buy a new alternator any ways and as for space i dont care i'll rip out my roof if i have too i'm not going to do that
ok, put 6, or even 4 nine.1's on a stack elec system and see if you can even keep your car running whilst listening to music and not getting high rpm's. Shit, I imagine even with high rpm's your car would have a hard time running if you were playing music anywhere enar loud.
on a stack wtf is a stack or do you mean stock? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
300m_on_xxx
BMW 325IS
300m_on_xxx
Fresno, CA
RandyJ
