Another which speaker question
  • 7
If you look at graphs you will see they are the same. One may do better off axis but that’s driver dependent.
So no matter the tweeter material, it's off axis is the issue? Is that what your saying?
I’ll show ya. These are almost the same minus material.
You will see they are almost identical up to a bit over 18k hertz. I can’t really hear past 15k.
And the metal drops off more on the top end. Btw. These are a freaking deal.
https://www.madisoundspeakerstore.com/hard-dome-tweeter/sb-acoustics-sb26adc-c000-4-aluminum-dome-tweeter/
https://www.madisoundspeakerstore.com/sb-acoustics-soft-dome-tweeters/sb-acoustics-sb26stac-c000-4-1-textile-dome-tweeter/
So it’s not the material you don’t like. It’s the tweeter itself.
I'm not so sure about that. I haven't been able to test enough diff branded tweets to be able to give my full opinion. Although, I have had MBQ, Focal in the past and have heard/read that they need some good amount of power to sound good, regardless of tweeter material. Oh yes also had CDT.
Yea I was planning on going that route. I'm sure it'll sounds close to what I'm expecting
16
745
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
925
They managed to turn Covid into a wedge issue.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
Sguirrelfeather
Sguirrelfeather
Mountain Home, ID
Boomin_tahoe
