Amp-Sub Help!
  • 2
v6ncali
I'm running an Audiobahn A1801Q amp (800x1 watts max) to power 2 12inch Audiobahn AW1208Q subs.. The subs have Dual 2 Ohm Voice Coils and are sed to be able to operate on 1 or 4 Ohms. I didnt not install these, the shop where i bought them did. The way they connected them was they split the one channel into to. So there is a total of 4 wires. Each sub getting its positive and negative feed. Is this the best set up i can run?
So the positive and negative wires coming out of each sub are going to their own channels? If so, that is usually a higher impedence setting which means lower power but keeps the amp cooler. How many channels is your amp? And what is it stable at in terms of impedence. For example, my amp is 190W.2 @ 2ohms. Your manual should give you that information. How many ohms are your subs? Also, since your subs are dual voice coils, you're going to have many possibilities. Answer those questions and we can help you more.
The amp is a 1 channel 800 watt max amp. I got two wires running from each terminal going to a sub each, so that one channel is being split for each sub. The subs have dual 4 ohm voice coils and are said to be able to operate in 4 or 8 ohms. The amps specs are : 400x1 watts @ 4 ohms mono , 560 watts x 1 @ 2 ohms mono. That is all i can get from the website regaurdin the specs.
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
I still have some Old school stuff that I really enjoy to this day. I still swapp amps and other gear I have from time to time and run for a...
17
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
v6ncali
v6ncali
Los Angeles, CA
v6ncali
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
