Alex's Silverado
The cool thing about being a human is we adapt to our environment. If you take your rear view mirror off u will adapt and get use to it, if you still have a rear view mirror your not loud enough lol. Mine fell off in every vehicle I owned and one time it took a chip out the window when it fell off and cracked window so no more rear view mirrors for me. Took about 1week and I got use to using my side mirrors.. But for real three 21s on 8k+ is gunna break your mirror.
Orrrr just setup a camera hooked up a screen in the dash or your headunit (assuming youre running one with a screen). Super super simple and very much worth it.
Every corner that gets cut in a build like this adds up very quickly to the whole setup not performing like it should.
-Running 3 21" woofers in a truck for starters isnt ideal at all because of the layout so that will certainly limit your performance.
-Trying to tune it too low IMO will hurt it quite a bit by the numbers although IF it works out it will be gnarly to the body
-Not going with a full wall, is going to limit performance hugely.
Not trying to hate...not at all. I was actually in the exact same situation when I was 17 building my first walled vehicle. I felt way too uncomfortable without a rear view so I decided to mount my woofers low (2 18s) and large port at the top of the box running horizontally all the way across just like the lifted dodge linked above. And the wall itself was contoured exactly to the rear window of the car and the wood was siliconed to the window. With this I could look out my rear view, through the port and out the back window. However this was 2002 and screens were super expensive and I was a struggling athlete trying to make a couple dollars on the side.
Definitely definitely suggest going full wall (youll ******* love it bro. Honestly...the look, the feel, and the results you get are well worth it!!) and run a good camera out the tailgate or even out the back of the cab at the top maybe. Then you simply have an easily accessible switch hooked up to your head units reverse input that you can either leave on permanently while you drive to glance at orrrrr have your regular screen controls on and if you want to switch lanes or look behind you just quickly flick the switch and have a look. But to be honest, you dont need it. Driver and passenger mirrors are all you need anyway. Its just like driving a work van/moving truck etc. No big deal, you get adjusted to it very very quickly.
Got the sides/ceiling and covered with resin on the outside
Tomorrow I'm hoping to do the baffle. This is the part I am least looking forward to. I wish someone else could do it for me.
After the baffle is done, here's all I have left:
1. Coat the inside of the wall with resin
2. Screw in the rear plexiglass and seal around it
3. Cut a bigger hole in my bed
4. Run RCA's and other small miscellaneous wires into the bed
5. Finish my new bus bar
6. Mount the TFE
7. Wire up the TFE to the subs
8. Mount my 125.4 and wire it up
9. Finish re-doing my door pods and figure out what to do with the tweeters
I really can't wait to be done with this. Lots of shit going on, and haven't been posting on the forums this last week or so
I cut the baffle in one piece, then couldn't get it to fit, so I had to cut it in half.
Then I got inside and traced the edges of the side walls so the cutouts fit
Then came actually mounting it after the sub holes and port were cut out
I'm almost to the top of the bottom cutouts with the inner 2x4's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
^That's a really slow way to do it, just letting everyone know
All the wood pieces of the enclosure are cut, glued, and screwed.
Tomorrow, I hope to add the last couple more steel pipes that will brace the baffle with the back wall, then resin everything.
Box came out to be about 32 cubes net tuned to 30-ish after all the 2x4's and bracing
adulbrich
Olive oil un-virginer
adulbrich
Ames, Iowa
ChaseinBass
