Aftermarket HU 2011 F150 w/premium Sony
  • 2
HardcoreBob
Dallas
I have fought with considering all the different options to keep my factory HU, but coming to the conclusion that I have spent so much on quality speakers, wiring, dampening etc. that I would be doing a disservice to myself to not run a clean signal.
No HUs are recommended for my vehicle due to climate control issues... I don’t give a crap about the climate control...
Does anyone have experience with an HU that fits the 2011 F150 well?
Can I expect a better signal using Apple car play for whatever streaming service I’m using?
My phone/ iPad is actually my receiver, but of course I want clean preouts.
Sent from my iPad using Tapatalk
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
680
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
813
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
HardcoreBob
HardcoreBob
Dallas
keep_hope_alive
    May 24, 2024
