Aftermarket head unit never turned on, and hasn't had the same issue since...
  • 1
Bm96
26
Boston
I recently had a Pioneer head-unit installed in my car (2013 Volkswagen GTI) about two months ago, model AVH-X3800BHS. It was done for me professionally as I don't have the knowledge to. A few weeks ago, I got into my car to head to the store, and started the car, but the head unit was completely turned off, no lights anywhere. I tried pressing and holding buttons and still nothing, so I tried to re-start my car about two or three times and still nothing. I drove for about half an hour to a store while it was off, and parked. When I got out of the store and back to drive my car, it started right up like nothing ever happened. And since then nothing similar has occurred.
I really want to know if there is an underlying issue here, like a loose power connection of some sort. Or, if this is just be something like a bug. I am not at all educated in this field and wonder why this happened, and would hate to have to yank out the unit to see if anything is loose behind it if I don't have to! Thanks
Are you planning on reusing the power pack? If yes cut the wires at the top red arrow only. Connect your new radio harness to the translucent one...
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
680
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
813
Bm96
Bm96
Boston
Bm96
    May 24, 2024
