Aero port help
ummm....will the port be external?
If not, you do know that the volume will change right? (which means the port length will have to change also to get the desired tuning)
this is true. if you add a port to a current sealed box it will no longer be 2.5 cubes. and then that throws everything I've said off.
3.5 - 25% ( if it is a common shared space box? ) = 2.625 cf gross 2.5 is acceptablebut either way the cvt is a **** sub lolz its a shallow mount
well thats what we have now...do u know of 2 tens that would sound good ported in a box around that size or a little bigger??
wow first sicaudio says oh just throw two 4's in there not realizing that drops it to about 1 cube for each 12 ported. haha then just says oh there **** subs anyway. gtfo you ****
no i didnt say that moron learn to fking read idiot lol
i wasnt the 1 that said anything other than you dont need 3 4" ports and i am also the 1 that said internally they would make the box way to fking small
again i say it
LEARN TO FUCKING READ STUPID
Im sure sicaudio will have the best sub you can buy for 50 each just give it a second
yeah i told him an fiq which i dont sell //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i said kicker cvr which still wont work very well and i do sell
and i said zeus which i do sell that will work.
if you aint helping the guy how bout you
G T F O
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
850
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
treylittlefield
treylittlefield
Sand Rock, AL
302yota
