Aero port help
one 6" would need to be 18.87" long. Are you using true flared aeros or pvc?
two 4" would need to be 17.86" long
yes better and just use 2 4" ports made from standard pvc it is just fine.round ports do not need the 12-16" rule and 2 4" ports is 25-26 sq " so its all good.
one 6" = 28.26 sqare inches of port areathree 4" = 37.68 square inches (and they would each need to be 27.76" long)
All lengths are for flared ports, if using non flared then subtract one inch.
ummm....will the port be external?
If not, you do know that the volume will change right? (which means the port length will have to change also to get the desired tuning)
BINGO
and 3 4" ports is way overkill
people keep forgetting that you only need 6-10" per cube with a round port......................
can you read any of this Amartin? where did i say anything even close to what you say i said noob?
That sounds like your telling him to port his 12's with 1 cube each.
after he said it was gonna be external //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
read 1st try to dis when u have a clue //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Here it is - you have the subs and the box, put two 4" EXTERNAL aeros on it, or one 6", and see if you like it. If not, try a larger box if you can. Just curious what amp?
a RF 800watt //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm fairly sure you will like the ported box better even if it is only 2.5 cubes. If you build your own boxes, or would like to attemp your first, then try about 4 cubes.
well its in a single cab truck and the most we could squeeze out is 3cubes...we're gonna port it then if it doesnt sound good we're gonna get subs that will work in that box //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Just a little curious with the aero port calculation displacement.
if 4" aeros at 18" long were used to calculate the cubic feet displacement of this wouldnt you do this?
V=pi(r^2)h ...... so V=3.14(2^2)(18) = 226.08 cubic inches
then cubic inches to feet is 226.08/1728 = 0.13083333 cubic feet
So my question is how are 2 4" aeros causing a displacement of 1 cubic foot?
im confused and want to use aeros on my next box i build haha //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
You would be correct, a 4" cylinder, 18" long = .13. But remember when calculating how much volume a port will take up in a box you have to use the outside diameter of the port, ie. 4.25" for a 4" port. I have no idea where he came up with 1 cube.
Thanks //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
treylittlefield
treylittlefield
Sand Rock, AL
302yota
