ExplitPlayer
I'm trying to piece together my first setup for my Camaro.
I'm looking for a single 12in sub setup, that will give me the deepest bass for the money. I want to keep my factory head unit, and everything else in the vehicle to remain stock. I've read that I'll have to use a LOC, and tap into my factory amp in my trunk.
I've been eyeing Rockford Subs; which one would you guys recommend?
My amateur pick;
Rockford Fosgate P3D4-12 Punch P3 DVC 4-Ohm 12-Inch 600-Watt RMS 1200-Watt Peak Subwoofer https://www.amazon.com/dp/B004UFHXNI/ref=cm_sw_r_cp_api_WMABybZDVZCT8
Also a very cheap but quality amp to be matched with it.
I've seen good reviews on this Amp
Planet Audio AC800.4 ANARCHY 800-Watt Full Range Class A/B 2 to 8 Ohm Stable 4 Channel Amplifier https://www.amazon.com/dp/B00HG6W1VM/ref=cm_sw_r_cp_api_oOABybC9F9XBR
Yes I know, the cheap part is cringing, but the car is more in the performance sector, not much of the audio end of the spectrum. I'm just so tired of the factory bass.
Any feedback would be greatly appreciated! Thanks!
My amateur pick;
