95 Mustang 5.0 Build Log
Getting resistors ready to easily snap into place for the ambient tweets.
Now how does that work?
Rather than cutting a hole into the dash for a center channel, I am creating a solid stage using an ambient stage setup. Theses resistors will "quiet" down the ambient tweets to the point to witch they are are more of a fill for that 3-4.5 freq fill that is tough to achieve in sq.
How is auto bad? Build that auto (470rw i believe) with a good converter and clutches, or just replace it with a built C4 and it will not be outshifted by any 5-Speed, plus it will last much longer, Mustang T-5's are hand grenades waiting to go off...
O trust me Im a diesel guy and all for autos just like manuals in cars... and unless its gunna be built into a 10 second car a manual will spank his @ss part for part on the same car with a manual...
Made some tighter fitting mounts for the 6.5" woofers, ran some better wire (11 awg Ixos twisted) and installed the 8 ohm sandstone resistors.
New next to Old:
Nice fitment:
Fresh wire:
The Lt Green on White is the Pos wire so this is where the resistor will go:
Nice clean plugs:
Bracket mounted, and it is ssssssssolid:
Woofer is in its happy place:
Picked up a Tsunami optima batt topper for the power/ground upgrade. Zapco DC Ref 650.6 looks to fit in the wheel well nicely. I will float it for better cooling. Power and ground dbs are mounted and solid, bout ready to start hooking up wires. Just have a few more things to add:)
Crossovers all wired in:
Slowly working in the power/Ground wiring:
Great chassis grounding point!!! I will be cleaning this up and getting a solid bolted in 0/1 awg ground cable in here tomorrow:
Plans to fleese a shell over this mess are in the future, BUT form follows function, so I am focusing on getting it hooked up for now:
Sneek peek of what is coming up soon:
Yeah these are going to fit VERY well and allow for some PERFECT aiming. If anyone owns a SN95 mustang the dash looks like it was cut to allow for an up firing midrange:)
SPLAudioHz
SPLAudioHz
Indiana
SPLAudioHz
