93 Dakota Wall build
Tits. Now fire it up! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifnG
I Know... I am so pissed about the Goliath:furious:. I plan in the next two days to pull it to see what exactly when bad and through in my old brutus.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
why only 1 18 im sure you can fit at least another 1 in there looks good so far though better get some vids up when your done
1 18" as it is is pushing it on space it only is a little under 7 cubes. this box is maxed out width and height. The only thing i could do is make it a couple inches deeper but then i would be forced to mount the amp in the bed which i am really not a fan of doing right now.
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
870
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
93dakota
93dakota
Ohio U
Savag3
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
