I am strongly considering putting in a Boston Acoustics Pro Series 8" sub in the trunk. Eventually I will be getting Boston 6.5" 3ways for the front stage. Will the single 8" work well with the components, or would the 8" be too small? Keep in mind the sub will be in the trunk, and 8" is the largest I can go.
With all of the above in mind, what would be the minimum wattage I should send to the 8" sub to make it effective from the trunk? The manufacture gives it a very broad range, 50-750w. My choices are either 150w, 300w, 600w, leaning towards 300w. I'm not going for all out SPL, more SQ, but I wouldn't mind feeling it if I decided to crank up the volume.
Thanks.
Thanks.
