75 watts on 40 watt rms 160 watt peak tweets
  • 2
momeigs
Makeshift Bass-head
Hey guys quick question. I’ve got a 1,000 watt 4 channel (150 watts per channel) that i’m going to hookup to 2 Skar NPX 6.5s (150 watts rms). I’ve also got two pairs of Skar NPX-Ts (80 watts rms) (320 watts peak) per pair. I’m going to run an active front stage with no rear speakers. Is it safe to run 75 watts on each tweeter if they’re rated for 40 watts rms but 160 watts peak? Thanks
you can run 1000 watts to a 50 watt tweeter if you set the amp gain right
heres how. the test tones are at the very bottom
Awesome, I figured as long as I set the gains right I should be set. Just wanted to make sure. Thanks!
Ok, i will go on this option. Thanks a lot bro for the help, i really appreciate again, Cheers
601
Welcome. You have a Crown Vic, Which year cruiser is it? You have a trunk big enough to hold a family of four - why three 8's and not a couple...
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
Let's if i can give my input too. 180 Watts is the maximum power your speakers can handle. And it is 4 ohms. And you're trying to find the...
27
Only a testament to their durability evl won't last that long id wait until the mojos gave up then go evl honestly and trust me unlike 99.5 of the...
36
6K
momeigs
Makeshift Bass-head
momeigs
Jacksonville
momeigs
    Apr 28, 2024
    Apr 28, 2024
