75 watts on 40 watt rms 160 watt peak tweets
momeigs
Makeshift Bass-head
Hey guys quick question. I’ve got a 1,000 watt 4 channel (150 watts per channel) that i’m going to hookup to 2 Skar NPX 6.5s (150 watts rms). I’ve also got two pairs of Skar NPX-Ts (80 watts rms) (320 watts peak) per pair. I’m going to run an active front stage with no rear speakers. Is it safe to run 75 watts on each tweeter if they’re rated for 40 watts rms but 160 watts peak? Thanks
you can run 1000 watts to a 50 watt tweeter if you set the amp gain right
heres how. the test tones are at the very bottom
Awesome, I figured as long as I set the gains right I should be set. Just wanted to make sure. Thanks!
momeigs
Makeshift Bass-head
momeigs
Jacksonville
momeigs
