usually box rise is triple your wired impedance so if you wire to 1 ohm, expect 2.5 to 3.5 ohm power out of your amp. if you wire to 2 ohm, expect around 6 ohm power numbers to your amp. Its a complete waste to try do a high powered setup at 2 ohms, literally no reason to do that at all. Hence why you'll only be tickling Zcons, HCCAs and all the higher RMS subs. Higher RMS does not mean louder, it just means you need that much power to get louder. This is why people generally throw double the sub's rated RMS and have zero issues with it, not because the sub is beefy, its because they are barely seeing rated power but they keep the signal clean. This is also the reason why most people wire to half ohm and lower on korean board amps which are tanky enough to do so on a daily basis with no issues.
For your goals, some b stock sundown ZV5 18s will easily get you there with a box tuned low making you slam 15-50hz with a strong emphasis on 30 and below.
Only suggesting 18s because that maximizes your airspace. Cone area does a lot for output. two 15s and two 18s of very similar beefiness, even if the 18s are weaker it'll still be a lot louder than the 15s. Cone area is king as long as you have the airspace to do a proper enclosure for it.
