4ohm to 2ohm??
ok so i need a good 4ohm amp then?
what would you guys recomend
im using a sundown 1500 with two kicker 4 ohm cvx's wired to 1 ohm. it SLAMS! thats what I would do, get a good 1 ohm stable amp. gonna be hard to find an amp that puts out that much power at 4 ohms.
1 last question. how do i wire them down to 1 ohm if there in different boxes
wire the coils parallel. then wire them parallel outside of the boxes. so you have 2 coils. put some wire between the pos of the first coil, to the pos of the second coil. do the same for the negative. then run a wire from the pos of the first coil, and teh neg of the second coil to your speaker terminals. do this for both speakers (both boxes) then just wire them parallel from the speaker terminals to the amp.
Wire all POS+ connections together
Wire all NEG- connections together
Voila, you have a 1 ohm load with 2 D4 subs!
Here is a picture as well:
ltr450racer690
ltr450racer690
west laffy
ultimate157
