2 different ohm speekers on a 2ohm 2 channel amp
I wired the 4 ohm sub to carry 2 ohms and only run 1 voice coil on the 2 ohm speaker so there both 2 ohms and put them on 2 different channels will this work
No cause that amp is a mono amp. It doesn't have two channels. If you wire both together with one subwoofer on one coil and the other on both coils they are going to cause issues with each other. Just run the 2 ohm and get rid of the other subwoofer. You only have 300 watts anyways so one subwoofer is a pretty good match for that amp.
It also has 4 speaker posts that doesn't mean 2 channels
You mentioned you have a box that will fit 2 subs? If the subs have their own chamber, you can run both subs. You will have to series the coils for each sub, then wire parallel wire them to the amp. that will give you a total of about 2.7 ohms. You won't get the full power, but it will still be louder than one sub.
So you are aware, there's nothing wrong doing this. I have done and done it quite a few times for the same reasons as yours.
Jim Klock
CarAudio.com Newbie
Jim Klock
P.a.texas
anisa.lewis
