4'' konaki super tweeters mb quart 6.5 add a woofer system and 4 5'' speakers
  • 2
loudcartunez
philly pa
MB quart 6-1/2" (Fits in 6-3/4" Location) Premium Series "Add-A-Woofer-System"
4'' konaki k01-t20 super tweeters
4 5'' volcanao loud speakers (mid/full range vocal)
mb quart 6.5 speakers
• Power Handling:◦ Peak: 260 watts per pair / 130 watts each
◦ RMS: 120 watts per pair / 60 watts each
• Titanium wet-powder-coated polypropylene woofer
• Rubber midwoofer surround
• Balanced Temperature Technology built-in to the crossover network
• Single outboard stereo crossover: 250 Hz 12dB/Octave
• 4 ohms impedance
• High-grade composite baskets made from specially formulated polyamide
• Top-mount depth: 2-5/8"
4'' konaki k01-t20 super tweeters ( not some cheap pyle or ebay tweeters)
300watt rms each
2'' titanium super tweeter
die cast aluminum frame
600 watt max
4/8 ohm2k-2.5khz
4 5'' loudspeakers/mid range (car or home) 4ohm they are called volcano they handle around 40 watts each and get very very loud i had them in custom a pillars in my truck they are for vocals/mid range in ur car
will condsider trades
mb quart 70 shipped
tweeters 50 shipped
5'' speakers 25 each or all for 80
will get pics with user name when u get a chance
The tweeter has to be crossed over somehow. Doesn't matter if it occurs at the HU, the amp or passively.
912
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
10K
loudcartunez
loudcartunez
philly pa
rebelfromva
    May 24, 2024
