4 channels, 1 sub and 2 6x9s
rickcd
Ive got an alpine MRV-F345 amp and im wanting to hook up a pair of alpine
type-R 6X9s and a type-R sub (4ohm)
The amp can run at 4 x 75W RMS. To power the sub im going to need to bridge channels 3 and 4, which alpine say will then total 300W RMS. So the plan is to have channels 1 and 2 powering the 6x9s and 3 and 4 bridged to power the sub.
I have no idea atall how to bridge it though, could anyone help me out with a diagram or something showing me how to do this?
Thanks
Rick
it's just a matter of what terminals you hook the sub up to. To bridge the F345 you use the channel 3 (+) and the channel 4 (-), and if you look at the speaker outputs of your amp you'll see that the term "bridged" identifying what terminals to use.
On a related topic. You said your type R is a 4 ohm sub. I don't think Type R's have ever been available as SVC's so you must have a DVC4 which presents a problem with bridging your amp. Your amp needs a 4 ohm load to put out 300w and a dvc4 can only get you 2 or 8 ohms. 2 ohms isn't safe for the amp, 8 ohms will work, but it will cut your power from 300 down to ~150.
ok cheers
regarding the sub, im pretty sure it is DVC (4ohm+4ohm) but cant you just wire the amp into just one set of the terminals?
http://www.alpine-usa.com
go to Tech Center, click continue without login and under the 2005 amps you'll find the owners manual for free download.
Ive got an alpine MRV-F345 amp and im wanting to hook up a pair of alpine type-R 6X9s and a type-R sub (4ohm)
Thanks
Rick
rickcd
rickcd
England
amartin_72
