Kicker L7 12" wiring
And if you have the DVC 2 ohm versions then you can NOT get a 1 ohm mono load...
Thats not true because not all the voice coils are 2 ohms, they may very a tiny bit, wired my dual 1 ohm solo x and it was wired down to .5ohms but read 1 ohm on the meter.one coil was 1.4 and the other was .7
That's called DCR and with box rise the whole ohm load changes. If he has two DVC 2 ohm subs he CANNOT wire to 1 ohm.
I knew they're was no possible way to wire his to 1 ohm.
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
8-14 guage wire. Sorry you can not get a final 1ohm load.
liyahsbrother2
liyahsbrother2
New Orleans, LA
tRiGgEr
michigan born
    May 14, 2026
michigan born
    May 14, 2026
