Optima Batteries
Red under the hood (It is a starting battery after all). And the yellow in the rear only if needed.
I see no reason to go threw the labor of installing the second battery. Unless you truly need the current.
I have a little *** alternator which is rated at 60 amps. (as you can see on my sig)
I have contacted a few companies about alternators and Ohio has one that is direct bolt on............ but it is reted at only 160 amps and they want $250.00 for it.
So while I save a few more bucks i was thinking on adding this battery that is just colecting dust. (i know is going to kill my currenct alternator faster) But damit i need to feel the bass!
my 15yr old stock 90a didnt have a problem chaging a red and 2 g31 blue tops...you should be fine
thanks dawg! thats what i wanted to hear!
I am planing on upgrading alternator but not until after tax return gets here.
now why the hell do they make focking small *** alternators! aggggggghhhhhhhh!
I heard and read a few post about people here having bad experiences after upgrading alt's which company should i stay away from?
hcoronado
hcoronado
Richmond Califas
audiolife
michigan born
    May 14, 2026
michigan born
    May 14, 2026
