2ohm bridged stable amp
Thank you very much.
I figured it was but I got confused on the 2ohm bridged part.I was thinking that would run it down to 1 ohm.Apparently that would only happen with a DVC 2ohm in parallel.
I figured it was but I got confused on the 2ohm bridged part.I was thinking that would run it down to 1 ohm. Apparently that would only happen with a DVC 2ohm in parallel.
You are correct in thinking this. It is stable to 2 ohms bridged because each of the channels by themselves are stable to 1 ohm.
Most amps today are stable to 2 ohms stereo, so that means its only stable to 4 ohms bridged.
Hopefully this doesn't confuse you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And yes, a DVC 2 ohm in parallel will yield a 1 ohm load.
shore
shore
Port Orange Florida
shore
Mike Mccabe
