2014 Accord Sport SQ Build keep_hope_alive
How's the trunk glassing project going? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif No rush, just curious!
Zero additional progress, birthday month for family and work deadlines. Soon, maybe for finals...
Rich V.
two months pass and all i've done is drive the car and enjoy the music.
...almost
i have tuned the car some more, and i use two laptops to do it
dash looks the same
i may rebuild these in the near future for better aiming and less diffraction
I could not get the rear tires to last more than 30k miles without being terribly noisy. 3 deg of negative camber on one side was the issue, and it's not adjustable. so i replaced the three rear link arms with adjustable arms and replaced the tires.
I also made a video comparing acoustical treatments for your viewing pleasure
hey I can't seem to find the ceiling tile you used in there doors anywhere. at least not without buying a while box of them for about $150. is there an alternative to the ceiling tiles that can be sourced locally? thanks for the great build log
This would work well, smaller pieces are easier to fit. Fiberglass is inert and not prone to mold if it gets wet.
Rich V.
sweet thanks for the quick reply. this would still need to be wrapped in plastic correct? even though its Inert. should i try to compress it before installing it?
I recommend 1 mil plastic. Don't bother compressing because it won't stay. Aluminum foil tape holds it in place and can protect from moving parts.
Rich V.
Thanks agin for the reply . There doesn't seem to be much info out there about sound absorbsion at least not related to car audio. I have two vehicle I'm working on at the moment . I think I'm going to try some (Roxul safe n sound)in one and the fiber glass in the other and see if I can tell the difference. I found this site has some good info. I'm sure you have forgotten morgen then I will ever know about this topic but thought I would share
Soundproofing Insulation Comparison and Installation Tips » Soundproofing Tips
Thanks for sharing. You can use either and expect similar results.
Rich V.
I thought you had two amps?? What happened to the wood that you were going to have H.depot cut out?? Looks different to me for some reason. Do you...
This is the max fuse sizes for the knu wire. The kca 4awg kit can supply 100amp to the rp1200.1 but it won't have enough left over for the rp75.4...
26
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
980
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
680
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
keep_hope_alive
Premium Member
Acoustics Engineer
keep_hope_alive
Quad Cities, IL
keep_hope_alive
pfft
    May 1, 2024
pfft
    May 1, 2024
