2007 Jeep Grand Cherokee Build
Is that big gap supposed to be in there at 27 seconds or do my computer speakers just not play what's there?
Its suppose to be there. Its part of the song/track.
Somebody needs some Audiotechnix. No offense but you have 8g going to the subs but it looks like you only have 6g for your power/ground. Why not use a bigger wire?
That's 4 ga for power & ground.
0 ga from front to back battery, 4ga from back battery to amp.
I would have done 0 ga but it didn't fit
Okay, thanks. I still haven't played it in my car but I'll try it out in there.
That's 4 ga for power & ground.0 ga from front to back battery, 4ga from back battery to amp.
I tried to run 4 gauge to one of my amps in the past and I was pissed when it didn't fit in the amp. I'm assuming that's the issue you had? The amp's power terminals don't accept larger gauge wiring?
I knew 0 ga would not fit. I tried it before when I had my old jeep.
Ah I didn't realize you had a second battery. It's probably fine then since it's a short run.
orphe
orphe
Houston
orphe
