2 questions
MOFOMAN
1. is this **** safe?!!
2. should i take my amp back to have gains reset after adding 2 more subs? (4 12s total)
my fault i have 4 12" all single 4ohms (2boxes) i have 1 wire going from the amp (only way it would fit) spliced into all the sub wires
so it's wired 1 ohm? it could look better than what you have, but if that is what you like then roll with it. Personally i would want some sort of distro block or something a little cleaner looking...
i thought i was at 2ohms? it was never to show off just some cheap subs.. idk i was thinking since i had 4 they would be moving some around my astro van but aint really that loud
got that ***** for dirt cheap $115 obviously there stuff is overrated but im on a budget
---------- Post added at 06:23 PM ---------- Previous post was at 06:23 PM ----------
why would i need two ground blocks?
MOFOMAN
MOFOMAN
Michigan
MOFOMAN
