2 Atomic APX 10s install
hazardous0388
well i reconed the second apx 10 yesterday and decided to build the box today. i actually went and drove on the interstate to see how it sounded. the box is 4.25 cu ft after all displacements with two 4 inch aero ports. i do need to add more bracings to the top and bottom pieces though. i will be doing the added bracing tomorrow.
I have two braces in the box now. In the last pic it only shows one, but i have one right next to that brace going from the top to bottom.
Box looks good an all but doesnt seem like enough port area.
thats what i was thinking before i built the box. i talked to jeff brown (dtbrown) on this forum about it prior to construction, and he said two full length 4 inch aero ports would do good for daily. So I tried it, and it does get really low and sounds good until I turn it up pretty loud and i hear the box flex.
as long as it sounds good then no worries. sweet lil subs.
u going to slamology? be cool to see a (kinda) local there besides me tommyK and Les competing
i wish i could. i install at my local CC and a competitor that took this year off, named joe who was on team soundstream, tsunami, maxxsonics, who also has helped me alot with my install, already said he was going. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif it ***** because i really wanted to go...//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
not at all.....my 10's are in 4cuft
also tuned that low, of course:rolleyes:
if you understood how the sub functioned in a box that large at a higher tuning, its basically meant for 2 12"s, which would perform better.
it is quite big...but i gotta add more bracing now anyways. so that will decrease the size which i didnt want to have to do in the first place.
yeah i figured, id be taking up atleast .5-1 cube of airspace myself.
Fantastic find. Thank you for sharing this.
14
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
Good explanation, thanks. I'll try installing that other amp soon. I have a stinger cap that shows my volts. It's reading 15v at max volume with...
17
hazardous0388
hazardous0388
Springfield, MO
hazardous0388
    May 16, 2024
    May 16, 2024
