1Ohm or 2Ohm Sub
I havent bought the amp yet. But wasnt clear on which sub is better(if there is a difference).
But, I'm looking to get the Massive audio P1000.1 or Memphis 1000d. But this isnt set in stone, just dont want to spend more than $250 on the amp.
You'll get the most power out of the sub if you get the sub capable of running at 1-ohm. Both those amps are capable of running at 1ohm. So it looks like that answers your question.
I would get the dual 2 ohm, and run the amp (that you purchase) at 1 ohm.
If you want to add a second sub, and the amp you get is .5 stable, then adding a second dual 2 ohm will drop it to .5
BzeBwoi
BzeBwoi
Addison, IL
helotaxi
vegang
vegang
