1994 T-bird wall teardown >2004 ford explorer build
anj46907
No Longer Truckin
after southern nationals in jville i started tearing down the tbird for retirement and starting new build for 2004 ford explorer.
whats going in the explorer
4-Soundstream T5 15"s
1-Powerbass 4000D
Powerbass mids and highs
Powerbass EQ
3-Kinetik batteries
Bunch-o-Dynamat
Bunch-o-1/0 wire
Double Din touch screen and to much more to mention..on with the pics...
the wall before
after
wall completely out
amps and rack coming out
after
got wires?
secks....
new car
more pics coming tonight of explorer build. bear with us itss day one of many to come.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif and thanks to ryan( lambofgood91) for helping with the tbird teardown
circled in red is what got cut out. it will be replaced with a false wall. the kinetik hc2400 and hc1800 slides in almost perfectly behind wheel well staggered on top of each other
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
883
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
anj46907
No Longer Truckin
anj46907
Bradenton, Florida
Marlo Stanfield
    May 16, 2024
    May 16, 2024
