150db playing music on 2400rms DAILY.....
i think i may be able to pull it off. im bout to switch up a couple things. im putting in a 4th order to try out today and upgrading my wiring to 0ga.
well i want to hopefully atleast pull a 149db but i want the 150. my friends doin a 149 on music with a single 15" w the same amp i have and no wall so im hoping for it
Are you wanting 150 on music on the Termlab meter or some other meter? I dont know a whole lot about numbers...But from I have seen there are very few(if any) single sub setups able to pull 150s on music on the TL.
Its very doubtful...and its going to depend WHERE you meter it. Doing a 150 sealed on the dash in a blazer is pretty difficult if you want to be able to play music...you could get it quite easy if you tune to 60hz and build a burp box lol
yea but the spl comp i compete in is based on music i dont want a burp box. like i said the way i see it is its worth a shot and ima do a 4th order
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Hello, I already posted in general but wanted to also post in here. I recently installed a set of used JL audio shallow depth 12W 1v3-4 inside an...
Makes sense. You may be right on the gain; 2 subs on 300 watts seems anemic.
46
5K
bgowdy
Heroes are remembered, but legends never die
bgowdy
Campbellsville, Ky
cx-7heaven
